Door locks
Moderator:ct575
atkinsonsteve
Door locks
Postby atkinsonsteve » Fri May 20, 2022 8:07 pm
2011 diesel.When I use the fobs to lock the car everything seams to lock,it sounds as though it locked,but pull any Handle and the car opens.thanks Steve.
andypryce
Re: Door locks
Postby andypryce » Sat May 21, 2022 9:29 am
The car will unlock itself if it senses a door is not shut properly, I had same on my 06 XJR, in fact it repeatedly cycled lock/unlock, much to the amusement of passers by. It was a slightly bent metal rod connecting the lock to the handle within the passenger door. Worth taking off the door cards and checking?
XF Sportbrake 2020 / XK8 1998
JimMann
Re: Door locks
Postby JimMann » Sat May 21, 2022 10:35 am
Hi Steve, are you pulling the handle whilst still holding the key fob? The key fob(s) need to be far enough away from the car to stop the signal from alerting the car to the fact that you are trying to gain entry.
Jim
Jim Mann
Banchory
atkinsonsteve
Re: Door locks
Postby atkinsonsteve » Sat May 21, 2022 12:34 pm
Thanks Jim that was the problem,just left the fobs in the faraday bag car locked.Thanks Jim saved me fretting over the weekend.
