XK8 Headlight LJA4501AH
malcolm.phillips45464
Postby malcolm.phillips45464 » Thu Sep 08, 2022 1:46 pm
Desperately needed, whole passenger headlight, or lens, for 1998 XK8, non powerwash - LJA4501AH.
My other side is brand new so needs tobe in very good condition with fittings intact.
No other new ones in uk and no plans for Jag to reproduce. Thank you
andypryce
Re: XK8 Headlight LJA4501AH
Postby andypryce » Thu Sep 08, 2022 11:58 pm
Try Eurojag.
XF Sportbrake 2020 / XK8 1998
Postby mike020150 » Fri Sep 09, 2022 10:56 am
And Autoreserve. Mike.
Postby malcolm.phillips45464 » Sun Sep 11, 2022 12:11 pm
Thanks Andy and Mike, trued both and non in stock. Autoreserve are keeping eye out for me. Im hoping somebody somewhere has one in the back of their garage..... but its a search been going on since March. Cheers both
Postby mike020150 » Sun Sep 11, 2022 5:50 pm
If you are prepared to look outside of the UK, you might find a new unit. This year, I am aware of one member who bought new from Eastern Europe and I also recall seeing new XK8 headlamps advertised by a US company. The latter may have been Welsh Enterprises but I can't be certain. It could be worth casting your net wider than the UK and firing off an email or two. Mike.
JimMann
Postby JimMann » Mon Sep 12, 2022 5:00 pm
Have you tried DCR Autoparts - talk to Dave Roche there. Very knowledgeable and did have stock the last time I visited.
Jim
Jim Mann
Banchory
Postby malcolm.phillips45464 » Mon Sep 12, 2022 8:28 pm
Mike and Jim, yes I've tried abroad including america - they are 'waiting for stock' at the ones I've tried. Im also told i need UK specific as they are different specs.
As for DCR, a comoany I've used before and contacted first and despite numerous phone calls and emails, since March, does nor get back to me and has never actually confirmed whether he has any or not. I enquired again last week and never got back to me again.
andypryce
Postby andypryce » Mon Sep 12, 2022 8:33 pm
Bit of a worry that there is none to be had..
andypryce
Have you tried the XK enthusiast club?
JimMann
Postby JimMann » Tue Sep 13, 2022 6:56 pm
Hi Malcolm, I must admit to being a touch concerned that DCR Autoparts "had not got back to you" so I made contact with Dave Roche myself today and he confirms that you and he had communication earlier in the process and most recently on Sep.05.22, when Dave responded to your latest communication within just a few hours. You then answered Dave's questions on Sep.07.22 which he posed in his message of Sep.05.22. So, a bit of a negative tone, and somewhat unfair, to infer that he doesn't get back to you.
I understand that today, Dave has now sent you a very detailed email outlining what may be possible / practical to solve your issue, but it is not simple. In fact, there are typically 5 - 6 inquiries a week to DCR Autoparts alone for XK8 headlamp parts and I do know that Dave is working hard to try and find a methodology where he can refurbish headlamp units by separating the glass to allow re-silvering of the lens. However, making that separation is not a simple task as the bond between the glass and the lens is particularly strong, so if any chemists out there in JEC land know how to dissolve that bonding agent, Dave would like to hear from you. There is already a supplier on standby to redo the silvering process.
I trust this allows you to appreciate that suppliers are trying to help, but in some instances the results can be frustrating and it doesn't help to portray them in a negative light.
Jim Mann
Jim Mann
Banchory
andypryce
Postby andypryce » Tue Sep 13, 2022 10:17 pm
I know that John on To The Garage has done videos on re-silvering, but it does look a bit complicated...
https://www.youtube.com/watch?v=-uhGw27ArwE
Postby mike020150 » Wed Sep 14, 2022 9:05 am
I think members need to be very careful if tempted to follow the youtube re-silvering procedure. In the clip, it is suggested that, along with heat from a hair dryer, petrol is a good solvent for releasing the glass from headlamp plastic housings. Since an electric hair dryer would be a ready source of ignition for petrol vapour trapped within a headlamp, the chances of accidentally creating a nasty explosion and personal injury would be high. There must be a safer way of doing it! Mike.
andypryce
Postby andypryce » Wed Sep 14, 2022 4:27 pm
Agreed, certainly would never attempt it myself!
Postby malcolm.phillips45464 » Wed Sep 14, 2022 7:04 pm
Hi Jim, i would have thought the role of "moderator" would involve checking the facts and speaking to both parties before issuing your ticking off? You've mentioned recent contact but not all my previous emails, phonecalls, voice mails etc that received no response. You say that my post was negative towards Dave and i want to be clear that im not wishing to be negative in this post as Dave has indeed contacted me as a result of your contact and i replied this morning, hoping i get his response soon. I am not angry with Dave in this response but yourself for passing uninvestigated judgememt.
JimMann
Postby JimMann » Thu Sep 15, 2022 2:21 pm
Hi Malcolm, you can express your anger towards me as much as you want, but if my intervention has gotten you a result in terms of finding a solution to your problem, then my task as a moderator and as the Modern XK Section Coordinator has been successful.
Jim Mann
Jim Mann
Banchory
