Wanted rear drivers side interior trim panel convertible X150
c.neil59458
Postby c.neil59458 » Wed Jul 07, 2021 5:00 pm
I am trying to locate a replacement trim panel as mine has been removed and refitted by someone who has broken/damaged several of the mounting points for the torx bolts. This meands I cannot fit the panel correctly so it has a tendency to move causing a problem with the convertible roof sliding panel on the drivers side which sticks and has a tendency to come out of the rails.
Trim colour is barley although I suppose I could get a different trim and get it recovered?
In addition the spring tension device mounts have been broken and repaired although I have fitted a new one with a new panel which is much better.
Alternatively does anyone know anyone who can plastic weld onto the original panel in the Doncaster area who might be able to repair the original panel?
Chris
trim panel
X Type x3 (Sold)
XE R Sport (Sold)
X150 Convertible manufactured 18/10/2005 B00084 (Sold)
X150 Convertible FN58 DXY
JimboV8
Re: Wanted rear drivers side interior trim panel convertible X150
Postby JimboV8 » Wed Jul 07, 2021 5:04 pm
2012 XKR, Black pack, Aero pack, Speed pack 8) :mrgreen:
​Past:-87'XJS 3.6L, 93'XJ40 3.2L gold, 95'XJ6 4.0L sport, 00'XJ8 3.2L sport, 2005 XK8 4.2L, 2009 X150 5L Portfolio coupe, in that order and enjoyed all of 'em. :D
c.neil59458
Postby c.neil59458 » Wed Jul 07, 2021 5:30 pm
Hi Thanks for replying
I need one for a convertible that link is for the coupe panel
X Type x3 (Sold)
XE R Sport (Sold)
Postby mike020150 » Thu Jul 08, 2021 9:37 am
Try contacting the specialist breakers, like Eurojag and Autoreserve, which advertise in the club magazine. Mike.
c.neil59458
Postby c.neil59458 » Thu Jul 08, 2021 8:00 pm
Cheers Mike I will
There are plenty available in the US but the prices are eye - watering
X Type x3 (Sold)
XE R Sport (Sold)
JimMann
Postby JimMann » Fri Jul 09, 2021 9:37 am
Hi Chris, if you type 'plastic welder near Doncaster' into your search engine you will get lots of 'hits' and it is even possible to buy a plastic welder kit for under £30. One of the hits that shows promise, although I have never used them nor have I any connection to the company is C&S Pro Spray, who claim to specialise in plastic welding on vehicle parts - especially bumpers.
If you have the broken pieces, or parts from which a pattern can be made to remake the broken parts, this looks like a relatively inexpensive way to go forward.
Jim
Jim Mann
Banchory
c.neil59458
Postby c.neil59458 » Sun Jul 18, 2021 3:31 pm
Thanks Jim
That dpes sound promising ill get in touch with them.
I have located a new one through eurojag but it is the fat end of £700 + VAT
X Type x3 (Sold)
XE R Sport (Sold)
JimMann
Postby JimMann » Sun Jul 18, 2021 4:30 pm
Hi Chris, that's a chunk of change. If you have the parts and the plastic welding can be made to work, the bonus is that you keep the original and save the outlay. I know which way I would try.
Jim
Jim Mann
Banchory
