for a few months now I have been the owner of a Jaguar XJR, built in December of 2003. Until now, I have been (and always will be) a BMW guy as I only have had BMW's before, more precisely 7 series BMW's. There are still two of these parked in my garage that are being driven only during the warmer periods of the year, but thanks to another road user
Although I'm no mechanic and therefore relying on a thrustworthy car workshop, all these years with the BMW's allowed me to collect a big amount of knowledge and equipment all around these cars. With the Jag on the other hand, I more or less started from scratch again, but I'm trying to read and learn something new every day. At least I got my hands on the full technical manual and I also have a working laptop fully equipped with the necessary interface, SDD/IDS and so on. Therefore, some basic infrastructure is available although I did not dare to use it until now to be honest, thanks to the knowledge about the damage you can cause by any wrongdoing in this matter. For my BMW's I have the comparable equipment at hand, too, but it took me a while to really using it way back when
Since buying the car I have driven a few thousand kilometers already and all in all I'm very happy with it, be it the ride comfort, the quality of the dipped and high beam lights or the engine as the cherry on the cake. There were a few things I had to get used to but I think most of them were manageable. Nevertheless, some questions still remained after reading a lot on different websites and forums, especially this one, which I'd like to share with you here. In case it's necessary or requested to move them as separate topics in the fitting subforum, please tell me to. Please forgive me using metric numbers as I'm used to them.
The first question is about the fuel range. Following the user manual the XJR has a fuel capacity of 84,5l of petrol thanks to the dual fuel pumps. With my regular driving I get a fuel consumption of around 11l per 100km (approx. 25 - 26 mpg), therefore the fuel range should be at least 700km per tank. In reality the reserve light comes up at around 560 - 580 km on the trip counter and I have not had the courage to go beyond around 630 km. Having done that and expecting the tank to be more or less empty, I could not get more than close to 70 liters in which means that there should have been some 15 liters left
The second one is discussed in another topic (this one: viewtopic.php?f=334&t=12399&sid=db7df2b ... 5a73aa7418) which I'm already following. My wipers work fine if you have them on permanent wiping or if you grab the wiper control for a single sweep long enough until the wiper is coming down again. On interval wiping however they tend to stop somewhere along the way after a while of wiping faultlessly und when this problem occurs, single sweeps don't work anymore either except with the technique described before. I guess, following everything I have read before, it is the wiper motor who is causing the trouble, is it?
The third and last question is about the front heated seats. The heating doesn't work on either of the front seats, whereas on the back seats, both sides are working properly. On the fronts, the lights on the dashboard come an when the button is pushed and you can adjust the three levels until the lights go out again. Unfortunately, nothing happens in the seats though. I'm not using the seat heating anyway, but for my passengers I'd like to have them in proper condition. I have already read that there is a so called Front Electronic Module that (among other things) controls the heating elements in the front seats and that is likely to occassionally fail at least for the heated sets. For example the eletric adjustment of the front seats is working properly and I don't recall any other malfunctions controlled by the FEM either. Is there any other potential cause for the heated seats not working or is the FEM the target to look at first?
Thanks to anyone who got this far and who can forgive a non-native speaker some surely existing mistakes along the way. Thanks in advance also for all yours answers and a warm welcome to this forum!
Best regards, Patrick
