XK150 DHC (Early) Rear Bumper Grommets
Moderator:MSB
Cathode
Postby Cathode » Sun Jan 22, 2017 6:59 pm
I've decided to remove and clean up my rear bumper and mounting irons. All looks good, and surprisingly even the bumper grommets have cleaned up well. However the grommets seem to have no means to fix them to the bodywork. Should they be glued or left floating on the irons?
Also can you advise the best order in which the rear bumper should be assembled/aligned.
Thanks in anticipation.
Re: XK150 DHC (Early) Rear Bumper Grommets
Postby mike020150 » Tue Mar 07, 2017 5:43 pm
Since no-one has come forward with an answer yet, it would be worth sending our new Forum Coordinator (Gordon Jones - classicxk.jec@gmail.com) an email. Mike.
