XK 120 gearbox roller bearing C.883
Posted: Thu Dec 01, 2022 2:02 pm
The original cylindrical roller bearing, which has been fitted to "JH"- and "SH"-gearboxes, came from HOFFMANN type R.M.S. 12 1/2L. This is no longer available after 70 years. The speciality with this bearing is that it has an outer ring with one collar. With this constellation dismantling of the mainshaft is easy.
In older bearing conversion lists you will find SKF, FAG or RHP alternatives. Also these bearings seem to be no longer available. SNG Barratt has no idea to get the right item.
Has anyone a solution for this problem?
