Hi there,
My windscreen wipers stopped working as well as my direction indicators. I noticed my ammeter is also showing a negative charge whilst running and a positive charge when ticking over..this all happened out of the blue they were working fine yesterday! All the other electrics are fine
Any ideas??
Thanks scott
xk120 wipers and indicators stopped working
Moderator:MSB
Re: xk120 wipers and indicators stopped working
I am not familiar with the wiring for your car but it seems strange behaviour. Is there a fuse for the items you identify? I would check the wiring for chafing somewhere causing a short as at low revs there is a charge and at high revs a discharge, perhaps as the engine rocks?
A short could well cause a fire if the fuse does not blow so look for signs of degredation if the insulation on wires aslo.
Sorry not too much help.
Paul V
Mk2 3.8
Nissan Micra K13
Porsche Macan S
Mk2 3.8
Nissan Micra K13
Porsche Macan S
Hello Scott,
poor conection at the fuse is the first check for your wipers and indicators as is a general voltage check if you have a meter?
Look at the fan belt, either for wear or tension. I suspect that becaus as your speed and load goes up the belt may be slipping?
