Headlights
Moderator:MSB
oddmog
Headlights
Postby oddmog » Thu Jun 05, 2014 3:12 pm
Any ideas how to improve the headlights on my XK150 without loosing the original Jaguar glass?
piman
Re: Headlights
Postby piman » Fri Jun 06, 2014 6:58 am
Hello Oddmog,
incandescent lamps are very sensitive to voltage, ie, a small drop in voltage has a large effect on light output.
To get maximum voltage at the lamps, fit relays near the head lights and feed them from the battery with large section cables. Ensure the earth connections are both clean and tight.
If the reflectors are past their best then investigate whether replacements are available.
