The rear carb on my 1950 XK120 is currently trying to destroy itself on the steering column. I believe that there should be a spacer under the front engine mount on the offside ( the car is RHD) but, according to my parts book, there should be a spacer under each front mount. I intend to replace the engine mounts but am not sure whether to add spacers on both sides. Any help would be gratefully received.
Derry
XK120 engine mounts
Moderator:MSB
Re: XK120 engine mounts
Hello Derry,
possibly it is only the damaged engine mounts that are the problem, so I would fit those anyway and then see how the engine sits. With damaged mounts the engine will be all over the place due to the large torque reaction when driving.
