Wanted: underbonnet aircon cable and bracket
Posted: Wed May 15, 2013 3:04 pm
I'm about to fit a new aircon compressor to my series 2 V12 and gas it with R134a instead of the R12 in the old one. Since R134a has a tendency to leak away, I want to add a small amount of protection for my new compressor by fitting the later wiring which, under low pressure conditions, allows a superheat switch in the compressor to disengage the compressor clutch and minimise possible compressor damage.
To make my life easier, is anyone breaking a late series 2, a series 3 or an XJ-S with the short 4 wire harness/fuse block (DAC 1408) plus the associated small bracket (DAC 1396) which holds fuse block to the compressor that they could sell me?
Mike.
