Wants
RichardSEL
Wants
Postby RichardSEL » Thu Aug 16, 2018 10:22 am
XJ6 series 1. 4.2L '72MY chassis -- an AED unit that sits between the two HD8 carbs -- known to work please!
Rear bench seat. Don't need the upright. Trimmer says mine's too far gone with the springs out and some breaks in the frame to do much with. Cover condition not bothered.
Mine's a bit too far gone...
RichardSEL
Re: Wants -- FOUND
Postby RichardSEL » Sat Aug 25, 2018 10:22 am
There's just too much bad history on the original AED unit (AUH300) that it's too risky getting a second hand one. Unless guaranteed to be "tested and working". SU re-designed this unit later in production, Gurlen sell them at £285. Many folks have just used a solenoid in the choke feed line as the simplest way
Think I've found one. Just waiting on the confirms all the way from Barrow-in-Furness
Got offered one from a scrappy but that turned out to be for a Daimler -- those were the only XJ6 varients to offer
an individually-shaped (like the fronts) rear bench
