XJ Manual conversion
Moderator:LJR
sean
Postby sean » Fri Oct 04, 2024 10:23 am
I was going to convert my Daimler XJC from auto to manual. I have decided not to anymore.
Over some time I have accumulated everything to do the job. Manual OD gearbox, New clutch, Flywheel, bell housing, pedal box with clutch master cylinder and Brake master cylinder , prop shaft,
Manual ski slope, gearstick with OD switch, gearstick gator, gear stick gator housing ( goes under centre console )
Still needed. Flexi clutch pipe and foam for sound deadening under console.
I won’t split this kit.
Selling at £2250 for everything.
Tel 07960487058
Email seanclarke01@aol.com
SimonH450P
Re: XJ Manual conversion
Postby SimonH450P » Fri Jan 31, 2025 10:22 am
Hi Sean
Did you ever sell this? Whereabouts in the country are you.
What condition are the constituent parts in?
Is the clutch new, does the flywheel need regrinding, does the gearbox need an overhaul, does the slave cylinder need an overhaul…. You get my drift. Don't want to spend £2k only to have to spend another £2k
1977 XJ6 4.2 Coupe, in need of a lot of love!
V12Smig
Postby V12Smig » Mon Feb 03, 2025 11:22 am
Simon, the manual kits have become stupidly expensive... I've seen pedal boxes offered for £750! Good luck in your search, perhaps try Piston Heads, Jaguar section on the forum, maybe someone there has the components you need..
SimonH450P
Postby SimonH450P » Mon Feb 03, 2025 4:12 pm
Hi Sean
Thanks for your replies.
I will think on as to strategy for the car.
