Screeching noise from steering.
When manoeuvring car at low speed there is a screeching noise from the steering especially when moving to full lock???????
Re: Screeching noise from steering.
Sounds like the drive belt slipping and squealing. Check the tension. On full lock the pump is working at Max output pressure and the relief valve in the pump sings a bit - come off the full lock stop a bit.
wot he said.....
and i would also consider a full fluid change, as it get a little tired and thin ,
you can do it yourself for £25
Many thanks guys, very much appreciated
