DD6 Coupe Fuel pump
jthorne
DD6 Coupe Fuel pump
Postby jthorne » Mon Sep 26, 2011 10:08 pm
I have a 1977 DD6 Coupe. My fuel pump was getting noisy so I've replaced the pump with an aftermarket pump. No I can hear the pump priming but the car will not start.
Please help!
Jon
1977 Daimler Double Six Coupe
almcl
Re: DD6 Coupe Fuel pump
Postby almcl » Tue Sep 27, 2011 7:28 am
Is fuel actually getting forward?
What pressure is your new pump spec'd for?
What pressure is it actually achieving at the fuel rail?
Al McL
XjRestorations
Postby XjRestorations » Sun Nov 27, 2011 9:56 am
Why did you go for the aftermarket pump over a genuine? I think cost would be very similar.
Do you know what pressure it is running at?
Just getting fuel to the rail is half the job - you will need the correct pressure too.
Kind regards,
Keith
