XJ Series 1 4.2 cold start
Camo
Postby Camo » Fri Mar 26, 2010 11:25 pm
hi,
I just picked up my new purchase, a series 1 Daimler Sovereign today.
My question is do I repair the electric cold start device or go to manual conversion.
And where is best to get the parts for either ?
Stu
Camo
Postby Camo » Sun Mar 28, 2010 4:34 pm
I have managed to fit a split pin to the top of the enrichment device around the plunger pin, this has enabled the device to actually work as its supposed to.
I had noticed the plunger was not rising when fired from cold but when held up the car would run, so assumed if I could hold the plunger up I could solve the problem... and it worked :D
I know its a stop gap but now I can concentrate on other things like cleaning the carbs and float chambers..
Stu
