I have been starting the car by manually pulling down the 2 jets in the engine bay whilst SWMBO starts the car. This is a problem when she isn't here.....
So, I have purchased a solenoid operated fuel switch and put it in the fuel feed to the AED and it works perfectly, car started first time and I then immediately switched off the fuel flow to the AED.
I already have the manual choke conversion fitted on the AED so the plan now is to lock the choke in the "on" position and then use a spring loaded switch to allow fuel to the AED to start the car and then release the switch to cut off the fuel supply, effectively an electric choke.
I will at some point overhaul the AED but this will remain a permanent solution for me. The overfuelling washes the oil off the bores and causes engine damage and the XJ uses enough fuel without chucking extra in
Total cost £13
