rear brake calipers Series 3 xj6
Posted: Tue Aug 24, 2010 7:52 pm
by CliveRothwell
I have just had the session from hell refitting the calipers onto the foot brake calipers whilst still up in the car. It took 2 (two) days! So, can the foot caliper when bolted up together with the handbrake caliper actually fit up inside the cage without dropping the cage?
Clive
Re: rear brake calipers Series 3 xj6
Posted: Tue Aug 24, 2010 10:47 pm
by almcl
Theoretically, yes. The procedure is described in the manual so someone must have done it at least once!
And only two days is good, it took me a week's worth of evenings last time I did it and I'm not sure I got it right then. I found either the spring/retractor would not stay engaged or those strange mounting bolts wouldn't locate. I ended up grinding a point on a couple of pad pins to use as guides when trying to locate the bolts, but I think this time if I have to replace the pads, I'll drop the cage.
