A smoky experience
Posted: Sun Nov 13, 2011 10:51 am
On the last day of the month I decided to allow my Series 2 V12's RFL to lapse for winter and to do things properly, I went for a final 10 miles' run to warm the engine before changing the oil and filter. Returning, a mile from home, progress was baulked by a tractor and I changed down manually to squirt past at the first oportunity. As I accelerated briskly and changed up, the tractor disappeared from view in a vast cloud of white smoke emanating from what seemed to be the right hand exhaust. Instantaneous thoughts of head gasket failure were allayed by normal gauge readings, followed by alternative diagnoses of brake or transmission issues. The brakes pulling to one side certainly didn't feel normal nor was the powertrain which exhibited odd misfire-like symptoms. The car made the mile home but as I drove towards the garage, it lost all drive. The good news surfaced when I opened the bonnet and everything was covered in transmission fluid. A rubber oil cooler pipe, located just ahead of the exhaust down pipe had split spectacularly and showered the exhaust, the offside front brake and everything else rearwards. It looked like a particularly messy waxoyling session! The offending hose (non OE, kevlar reinforced) had replaced a 30 years' old original as a precaution a mere 4 years and very few miles ago. The moral of the story is; beware modern replacements! The original hoses are no longer available from JDHT but later versions (CAC3097/9) are. These are much longer than the originals but frustratingly, just too short for one expensive hose to replace both the originals. Concours owners would weep upon seeing the underside of the car. However, looking on the bright side, I won't have to waxoyl her this year.
