LAZY GEARBOX
Posted: Thu Aug 21, 2008 4:22 pm
by tinyloughlin
i recently took my v12 sov for a quick spin after it had been standing for a couple of weeks, and although everything was fine at first and the gm400 gearbox shifted through the gears as it should.... after i gave it a bit of gas in order to achieve kickdown (of which it did quite happilly) the gearbox will no longer shift out of 1st. can any of you fine people and enthusiasts for these "Thatcher Cabs" give me any pointers?
many thanks
tinyloughlin
Posted: Fri Aug 22, 2008 8:13 am
by almcl
Not in any sense an expert on the GM400, but check fluid level and then the pipe to the vacuum modulator.
There is a check for a permanently energised detent solenoid but you really need the manual for that, and beyond there, there are lots of oil pressure checks but again the manual is required.
Posted: Fri Aug 22, 2008 3:42 pm
by tinyloughlin
hi al
thanks very much for your advise, i'll let you know how i get on.
cheers
joe
Posted: Mon Aug 25, 2008 12:37 pm
by tinyloughlin
solved it!
please excuse my laymans terms but the reason for the gearbox's reluctance to shift up was to do with the kickdown switch. its the one that is connected to the throttle pedestal and that is activated by the throttle cable when the peddle is fully depressed. it seems that the switch was slightly deformed due to a sudden and rather violent depression of the gas peddle which locked the swich in the closed possition and therefore keeping the box in constant kickdown mode. all i have done is fiddle with the swich to make function correctly and now the box shifts up and kicks down as it should. panic over
Al thanks again for your advise
Posted: Tue Aug 26, 2008 9:36 am
by almcl
Well done for solving it, glad it wasn't expensive!
