Selector
Jag 1979
Selector
Postby Jag 1979 » Fri Dec 04, 2020 6:07 pm
Hello all, my selector on one of my Jags is very stiff?
Its seems hard to push it into the R. The revers gear is fine/ but it seems as the problem is with the selector itself?
PaulGover
Re: Selector
Postby PaulGover » Sat Dec 05, 2020 1:40 pm
It's probably not the same problem as I had, but in my case is was the ball and socket mechanism at the gearbox end of the cable had seized. As a result, I sheared the ball off the gearbox arm. So, a good place to check first, if you have a ramp or other means of getting the car up in the air. If the joint looks OK, disconnect the cable at the gearbox end, and check it now moves smoothly from the cabin. If it does, there's a problem inside the box. That's beyond my ken. If it looks rusty, remember to grease it in future services, like the workshop manual says!
Failing that, I'd start by taking the "ski slope" off and have a look to see if anything's fallen into the linkage at the cabin end. There tends to be a rat's nest of cables that should be there, plus coins, sweet wrappers, whatever, that have sneaked through the slot by the gear lever.
Jag 1979
Re: Selector
Postby Jag 1979 » Sun Dec 06, 2020 3:52 pm
Thank you Paul for your advice.
I will take what you said on board, and when the weather is better I will have a look.
Regards Karl
