Correct fluid for auto 'box and PAS?
XJ_Driver
Postby XJ_Driver » Sun Apr 26, 2020 2:47 pm
I'll need to top-up both the automatic transmission and PAS fluid on my Series 2 XJ6. The handbook recommends Mobil ATF210, Castrol TQF, etc. What would be a suitable modern equivalent?
Advice appreciated. Thanks.
Best regards,
John.
2003 XJ8 3.5 SE
1979 XJ3.4 Se.2
PaulGover
Re: Correct fluid for auto 'box and PAS?
Postby PaulGover » Mon Apr 27, 2020 9:50 am
Two minutes Googling throws up suppliers of both the Mobil and Castrol oils you mentioned. The old stuff is generally known as "type 33F". I've been very satisfied with Morris's lubricants in the past, Their equivalent is Liquimatic 33G. You should pay around £33 for 5 litres.
XJ_Driver
Postby XJ_Driver » Tue Apr 28, 2020 2:41 am
Thanks Paul - much appreciated. Following your suggestion, a quick google search turned up ATF to Ford specifications M2C33F and M2C33G (although I have been unable to establish what the difference between 'Type F' and 'Type G' actually is?). However, both specs appear compatible with Borg Warner transmissions pre-1981. A subsequent search on amazon revealed several UK based oil blenders selling 5 ltrs of their own brand ATF to this spec for under thirty quid. The best deal I could find being Smith & Allan at £22.74 including UK delivery.
Best regards,
John.
2003 XJ8 3.5 SE
1979 XJ3.4 Se.2
eastendjohn
Postby eastendjohn » Thu Oct 26, 2023 12:22 pm
Why am I surprised there aren’t more recent posts on this subject as technology has moved on. I have a 420G engine with automatic transmission and current research (internet) suggests (Circa2023) ATF Dexron 3 or DX111 with a top-up of Lucus Transmission Fix.
Any contrary advice welcome.
poprivet
Postby poprivet » Thu Oct 26, 2023 4:13 pm
Opie Oils sell Castrol TQF
https://www.opieoils.co.uk/p-77269-cast ... tid=111998
On that page it gives the specs. You may be able to locate others that are suitable and perhaps more recent blends.
eastendjohn
Postby eastendjohn » Thu Oct 26, 2023 4:40 pm
Very kind of you. I use Castrol Classic motor oil so this may be where I need to go, thanks.
