Interesting occurrence yesterday. Went out into town shopping, came home and parked on the drive. After an hour or so moved the car into the garage and found a patch of oil on the drive about 6" diameter. Looked under the car where I had just parked in the garage and found a patch of pink fluid on the garage floor - same size or a bit bigger.
Today put car over the pit and wiped off the worst of it (underside quite "oily" anyway, so can't figure out where its coming from). Started engine and no signs of leaks. Took car out for 10 mile round trip and returned to garage over pit. Not a sign of a drip anywhere. Fluid now up to temp so sequenced through the gear selector and dipped the g/box with engine running - level not easy to see with clean fluid but seems to be top mark on stick.
Borg Warner model 12 g/box - fluid changed a couple of months ago - and I thought I had the level correct after the change. Ambient temperature on both days about 30 degrees C and engine got very hot but didn't overheat.
I can only think that ambient + engine temperatures became so high that the ATF expanded and somehow overflowed - in which case I must have overfilled it when I changed the fluid. Is that a reasonable conclusion or should I still be looking for a leak?
Robbie
ATF spillage
Daimler Sovereign S1 4.2 1971
Re: ATF spillage
Robbie - I had a drip from my XJS V12 that I first put down to the newly refurbed rear axle but on closer inspection turned out to be ATF.
I checked out the gearbox but found nothing of concern. Finally traced it to a split PAS hose.
Worth a look in your case?
Re: ATF spillage
Thanks David - I checked the PAS reservoir this morning and it's still full - and I can't see any leakage from the steering gear or hoses.
However, I think I'm making progress. There is a vent hose for the gearbox the top end of which is bracketed to the filler/dipstick tube - and the bottom end of mine has come off and is hanging loose against the transmission tunnel. According to the parts book the hose should terminate at fitting part number C.35844 (NLA) but the diagram does not show where this fitting attaches to the g/b casing. I have had a good look round and I can't see it from under the car. Does anyone know these gearboxes well enough to guide me as to location - I can't even be sure which side of the box it should be. The detached hose may of course be the reason for the ATF overflow.
Many thanks.
Robbie
Many thanks.
Robbie
Re: ATF spillage
Update. I sucked 250ml of fluid from the gearbox today and then drove the same circuit as before in the same 30 degree ambient temperature to replicate the conditions preceding the earlier fluid loss. Result - no fluid loss at all on returning home and parking up. This is consistent with the idea that the earlier loss was due to high fluid level and high temperature even though the level was not higher than the upper line on the dip stick.
I then dipped the g/b as before and the fluid was down to halfway between the two marks on the stick (following removal of 250ml).
So far so good, but I still need to find the stub connection for the breather/vent hose. I had another thorough look using a mirror and torch just now, but can't see anything remotely like a connection stub. Looking at the parts books, there was a change of dipstick and vent design at chassis no 7L.4841. My chassis number preceeds the change but the parts fitted appear to be a mixture of earlier and later components - and I know that the box was overhauled by the PO. It is not a replacement because the heritage certificate numbers match the box in the car. Nevertheless I suppose it is possible that the vent hose fitted was made redundant when the overhaul was done - but then where did the "overflow" fluid come from the other day?
Any thoughts welcome.
Robbie
Robbie
Re: ATF spillage
Robbie,
Just had a look at three parts manuals XJ 6 and twelve all the same arrangement Looks to me as though the vent pipe plugs onto a stub pipe on the off side of the box. Or in other words the rubber hose passes over the top of the box and connects to the box. Incidentally the upper end of the vent hose connects to a "tee" piece connected to the filler/ dip stick metal pipe allowing any vented oil mist or whatever to drain back into the box.
At 23.40 tis past my bedtime
Hope that helps
Hope that helps
Re: ATF spillage
the GM400 boxes also have the vent as Phil describes, its a simple nylon pipe press fitted into the casting to allow the box to vent,
this can be seen in the pic below, but again , this is a 3 speed GM400 as used until the introduction of the 3.6 engine which then got ZF ,
3473 by MyPix on Talk Photography
when complete, the vent pipe is extended and simply clipped tot he case as below, ,nothing more
4033 by MyPix on Talk Photography
this could have been the power steering reservoir overflowing, as the cap is vented, these would be the only two sources of ATF in the car, my money would be on the power steering personally ,
Re: ATF spillage
Found it - I think! I saw this before but it looked to me like a slot headed adjuster with lock wire to secure. It is opposite the greatest area of fluid contamination so that's a confirming pointer. The hose is hanging loose on the opposite side of the g/b. I will connect up the hose to this and fit a new clip then clean up the surrounding area properly. Thanks both for your input - that was just the guidance I needed!
Robbie
Robbie1996 4 litre XJS Celebration 2+2
Re: ATF spillage
The nylon pipe (referred to by BB) was kinked and crushed so I binned it and fitted a 10mm diameter fuel hose and clip (which is what I suspect you would get if you ordered C38514 again). At the top end the dip stick tube "T" connector referred to by OT was not present - instead the earlier tube design with no "T" vent connector had been installed - which makes me wonder where the vent outlet on the earlier design was taken to. I made up a temporary bracket and gauze filter head for the vent so I could get the car mobile (it goes to the body shop next week for a bit of welding) and will try and source the correct dipstick tube later, although I suspect that will prove difficult to find.
Robbie
Robbie
