What should the crank pully bolt be torqued to? (I think engine is a mid 70's 3.4) Haynes doesn't say
Where is the engine number located and how do I decode it to find what model it was fitted to?
Is there a way of ID ing the type of head fitted? I have a casting number in the plug valley closest to the bulkhead, on another forum it said this was only on pre67 cars. Anyone got that sort of info?
thanks fellas
crank pully bolt torque setting?
Re: crank pully bolt torque setting?
The workshop manual for the series 2 XJ6 gives the torque setting for the crankshaft as 125-150 pounds feet or 17.3-20.7 kgf/m.It also says that it is a 3/4in UNF BOLT.
