20/50 engine oil in 12cyl daimler
ipburrell1962
Postby ipburrell1962 » Tue Feb 24, 2009 4:35 pm
hi guys!,
at present my 82 double six is filled with duckhams 20/50 oil,which i plan to use again when i change the oil and filter before taking the car out of storage in april, i was speaking to another classic enthusiast recently who reckoned that millars 20/50 semi synthetic was a better bet, for the v12,and another guy who runs a six cylinder triumph (of 70s vintage),who swears byhalfords classic 20/50!!.
do i stick with good old duckhams?,or change to a semi synthetic 20/50?,any advice welcome.
cheers ian. :D
any advice on 70s xj12 purchase and ownership welcome good and bad!!
almcl
Postby almcl » Thu Feb 26, 2009 10:16 am
This is one of those imponderables, Ian.
I used to use Duckhams 20W/50 but no one stocks it round here any more. So I switched to a locally manufactured (Morris) brand. From the farm machinery shop it was £4 a gallon. However, this winter, in an attempt to rationalise at least two of the cars, I switched both the V12 and the AJ6 to a higher grade 15W 50
http://www.morrislubricants.co.uk/scrip ... Product=48
They both seem quite happy on it although it is quite a bit more expensive.
I may even switch the XK engined car to it when I complete the rebuild but only if I manage to reduce its consumption from the 300 miles per pint level!
Al McL
ipburrell1962
Postby ipburrell1962 » Thu Feb 26, 2009 1:51 pm
hi al,
thanks for the usual rapid reply!,and thanks for the attachment,ill look into that later. i can get duckhams 20/50 no problem by courier from a company in eastbourne,but of course shipping runs out at between £10 and £12 for a case (4 4litre containers) i think ill stick with it for now anyway thanks again. ian. :D
