Cross thredded spark plug
tinyloughlin
Postby tinyloughlin » Wed Sep 03, 2008 7:01 pm
i have noticed recently that my v12 wasnt running as smooth as it should so after investigation i discovered that there was vapor puffing out around spark plug 5A. i decided that the obvious fix was to just tighten it so this i did without realising that it was cross thredded and now i have made matters worse! the plug will not go back in correctly, the thread in the hole looks slightly damaged and now piston 5A will not fire at all. it doesnt help that this is the most difficult plug of the lot! has this happened to any of you before and if so have you any tips in regards to tooling/methods etc as to getting that spark plug in? as i am really dreading the idea of a 1/2 engine strip-down.
cheers
1988 soverign v12
almcl
Postby almcl » Wed Sep 03, 2008 9:53 pm
Not on a V12 but I did manage to chase the plug thread on an XK engine using an old plug, with notches filed into the threads.
Might be a bit more tricky on the V12's tapered threads. A machine shop did put a nice insert in for me eventually but the head had to be off for that although I think one of our local shops can also do it with the head installed.
Al McL
tinyloughlin
Postby tinyloughlin » Thu Sep 04, 2008 6:35 am
cheers Al
i think because that particular hole is the most awkward to get to it will be a job. what i am going to try is to remove about 7 to 10mm of thread from the spark plug and clean up the hole thread as best as possible then try to refit it. if not then its head out and up the machine shop.
i'll let you know how i get on
many thanks
1988 soverign v12
almcl
Postby almcl » Thu Sep 04, 2008 9:15 pm
At least one shop around here will come to you. Not sure what the cost is but I've seen them rebore and replace a piston (not on a Jaguar) right in the guy's garage.
Might be worth asking? You could clear up the valley of death for them, remove the throttle pedestal, and everything else. If they still can't reach it, nothing's lost, you'll have to pull the head but, if they can, you've saved a quite a bit of time.
Al McL
simon4253
cross threaded spark plug
Postby simon4253 » Sat Sep 06, 2008 5:57 pm
you can buy sparkplug thread cleaning tool fairly cheaply from toolmaster etc which is not much larger than spark plug which should be enough.access to airline bloer to remove swarf from cylinder is recommended though. good luck and don,t try to rush it!
tinyloughlin
Postby tinyloughlin » Sun Sep 21, 2008 9:36 pm
solved it! i took my time and completely cleared the "valley of death" towards the rear of the engine which included the complete throttle pedestal and coil assembly, and the oil pressure sensor? in order to get a good run at the dodgy threads with a thread cleaner that i got from ebay. anyway i took my time working it in and out clearing away any swarf as i went and a new plug went straight in. However i cant test my work because when i try to start the car all i get is a clunk, which leads me to believe that the starter motor has jammed. i am not suprised as the car has only been used a few times this year and six weeks since the last. it will be worth it in the end though! a big thanks to Al & Daimler for the advise.
1988 soverign v12
almcl
Postby almcl » Mon Sep 22, 2008 8:10 am
Good news!
Hope you get it started soon. Is the battery fully charged and can you turn the engine by hand?
Al McL
tinyloughlin
Postby tinyloughlin » Mon Sep 22, 2008 7:05 pm
plenty of juice in the battery although i have not tried to turn the engine by hand yet. how is the best way to do that? sorry for sounding thick but i really am a novice in regards to motor mechanics.
1988 soverign v12
almcl
Postby almcl » Mon Sep 22, 2008 9:28 pm
There's a nut on the crank shaft pulley. You may be able to get a socket and breaker bar on this and turn it by hand.
Al McL
tinyloughlin
Postby tinyloughlin » Mon Sep 22, 2008 9:59 pm
cheers Al, i need all of the help that i can get. i'll have a crack at it at some point this week and let you know how it goes.
cheers
1988 soverign v12
simon4253
non starting v12
Postby simon4253 » Thu Sep 25, 2008 7:27 pm
you should just about be able to tap ( not beat!) starter (o/s under manifold) which may be enough to free it. this may work for a fair while if used regularly but let me know if not as i do have a few starters left. not too easy to do on floor though. good luck and hope you are cruising again soon
tinyloughlin
Postby tinyloughlin » Sat Sep 27, 2008 8:16 am
oh dear! i gave the starter a couple of taps and then tryed to crank the engine but no joy. so i got under the front with a bar and a 22mm bit to turn the engine manually and it would only turn a couple of times in any direction and then stop as if something internaly was hitting something?. i gave the key another turn and the starter spun the engine up to the point of obstruction then wouldnt turn it any more. i am completly lost as to what it could be as the last time the engine run it was mechanically healthy with no knocking, tapping or enything unusual although that was about 8 weeks ago. all i have done since the last time the engine was running was to clear the valley and change 4 x spark plugs at the back of the engine. i am now praying that one of you fine gentleman will be able to give me an inexpensive diagnosis of point me towards something really simple that i have missed?
1988 soverign v12
almcl
Postby almcl » Sat Sep 27, 2008 1:49 pm
Tricky one to diagnose from a distance!
Revisit (in your mind) all the actions you took when changing the plugs.
Is it possible that something could have dropped inside one of the plug holes?
At worst, you're going to have to pull the plugs you changed out, then ferret around inside each cylinder with a magnetic probe, chewing gum on a stick &c and see if something has managed to get detached inside one of the chambers. It might help to have an assistant turn the engine by hand while you look down each of the cylinders.
If you can get access to a boroscope or other mini fibre optic seeing device, try looking with that.
If you can't find anything, try turning the engine by hand with just the plug whose threads you repaired removed.
Let us know what happens?
Al McL
tinyloughlin
Postby tinyloughlin » Thu Oct 02, 2008 9:32 pm
the plot thickens!! Almcl was absolutly spot on with his diagnosis of something falling down one of the spark plug holes! i took out the 4 plugs that i had replaced recently and and inserted a telescopic magnet and out came a screwdriver bit that droped off at some point and had fallen into cylinder 5A. i put everything back together and cranked the engine and it burst into life (well chugged at first) then i noticed a hell of a lot of thick steam coming from the exhaust pipes, especially from the off side pipe. it was the same sort of steam like smoke that you get when a head gasket blows (as has happened to me on a s3 4.2) so i dipped the oil to see the condition of it and to my horror the dipstick was covered in a water infused oilly muck that looks like Mars Milk. because the car has not been started for well over 7 weeks and was running fine before then (apart from the rought running caused by the baddly fitted spark plug) and because i forgot to block the spark plug hole, didnt close the bonnet properly before going on holiday! i can only assume that the engine has become full of water especially through the open hole in the offside bank, and then infused with the oil once the enging started running. i am doubtfull that i have a knackered engine as it has not even done 80 k, has never boilled over or run hot under my ownership and and as i said before...was running fine untill i negleted it to the elements. so i am going to change the oil & filter and check the plugs for any deposits (REALLY CAREFULLY this time) and clean them if nessesary and i will let you all know how it goes? again any pointers are more than welcome especially as they are always right.
1988 soverign v12
tinyloughlin
Postby tinyloughlin » Fri Oct 03, 2008 8:53 pm
well i changed the oil and ran the engine and at first there was no smoke. however it returned within two minutes though still only blowing from the off side pipe. i have a funny feeling that some damage was caused by eiether the water or the bit that fell into the chamber. i knew i should have got a lexus lol!
1988 soverign v12
