Hello,
Having asked JDHT and then Jaguar Classic, my engine seems to fall within a gap in records where even the Engine Serial Number is not recognised. I am hoping that the engine I have is one of the Higher (10:1) Compression Ratio Pre-HE Engines, but am currently stumped and so it seems are others; hence, can anybody out there help with details and/or identification?
The story I have is that a 1981 Series 3 had its engine replaced in 1991 with this Pre-HE (Service Replacement) where the Engine Part Number is stamped as RTC2691SR ... however, Jaguar Classic do not recognise this Part Number. Furthermore, my engine is also stamped with the Serial Number 3S1960F where Jaguar Classic again do not recognise this as a valid Serial Number - it should start with 8S apparently, but mine is most definitely 3S.
I am really trying to ascertain whether the numbers prove this engine to be a 'normal' Pre-HE or the later 10:1 Pre-HE ... it is a Pre-HE. Alternatively, I would do a compression test, but with the engine being on a pallet awaiting clean plus fit, then a little difficult. Equally, I want to make sure that I have what should have been the 10:1 Engine.
Can anybody recognise and translate the numbers?
Otherwise, I may sell this engine to buy a HE ... my Pre-HE only has 5000 miles on it in case of any interest, lol.
Many thanks in advance
Wolfie Souter
Westbury, Wiltshire
Pre-HE Series 3 Service Replacement - But, what is it?
Re: Pre-HE Series 3 Service Replacement - But, what is it?
It might be worth also posting this on the XJS engine section as well where more V12 owners will read it.
Also at https://forums.jag-lovers.com/c/v12-engine/19
Have added a pic of the numbers to show that they are all very clear - however, didn't notice until I looked at the pic in detail that there is a further number further within the V ... 16MR82 ... whatever that is ...
Still hoping that somebody can offer a definitive, thanks
Regards, Wolfie
Regards, Wolfie
Google for rtc2691sr throws up a few hits as "Exchange engine 5.3 S3".
David Manners recognizes the part number as "RECON ENGINE 5.3 XJ12", though no further details.
My XJS manuals CDROM has RTC2961R superseded by RTC2961SE (neither of which are yours...) , but list neither in the actual part number index, so I suspect the supersession table covers more vehicles than just XJS.
It looks like you need someone with an old paper XJ6 SIII V12 parts manual.
Hello Paul,
Well ... after a bit of vigorous cleaning, the RTC Label came away (glued to the engine block) and underneath - was another Engine Number of: 8S20593HA ... picture attached ...
From what you mentioned about 8S numbers, this looks promising and I hope that it means something plus is related to whatever was done to the engine as a Service Replacement!!??
What I thought would be easy transpires to be difficult ... I was trying to be able to 'prove' that I had a 10:1 Compression Ratio Pre-HE Engine - as it allegedly was a Service Replacement fitted to a 1981 XJ12 Series 3.
Suppose the next step is to take cylinder pressure readings, but anybody know what a guideline pressure should be (in Bar or PSI) to determine whether the CR is 9:1 or 10:1 ?? I have seen some formulae online, but difficult to get a clear 'number' ...
Did quickly check a couple of cylinders, but my battery was only part-charged - gauge read 6 Bar, which looks awfully low. Battery being recharged ...
Again, anything constructive very much appreciated.
Regards, Wolfie
Westbury, Wilts.
Regards, Wolfie
Westbury, Wilts.
(a) I'd take a punt "16MR82" is a date 16 March 1982...
(b) Attempts to measure C/R using a compression tester are doomed, even on a new engine, because the pistons, valves and air are all moving, and worse, on an old engine, everything leaks like a sieve, The manufacture's C/R is a static calculation defined as total cylinder volume at BTC divided by total volume at TDC, where "total" includes any gouges in the piston heads to clear valves, funny cylinder head shapes such as the May fireball head, etc. In theory you can do it with a pipette full of paraffin and a dismantled engine, but I doubt you'd get a good answer on an old engine due to leaks.
Apparently there's a device called a "Whistler" (I've seen a picture of it's mother
). It does something scientific to do the real measurements and calculation.
See this youtube video. It may be available at a race track or engine tuners near you.
Wolfie,
With the vagaries of potentially worn engine, stuck rings, unknown valve duration etc etc, I'm really not sure I'd use a cylinder compression test of giving me any confidence of a specific compression ratio?
A regards 6 bar (87 psi) , that's way too low for a good engine with rings operating correctly etc. I think you're looking closer for 220+ psi in a high-comp Jaguar V12.
If you don't want to lift the heads, I think you'd be better, confirming with camera that you've got pre-HE pistons and then using a dti or even a simple but accurate, measuring stick and manually turn the engine to measure the degree of piston movement that you get in a cycle and then try and work it out.
Wolfie, I would suggest you also close one of these 2 identical threads that you've got running on the different forums here. It just gets confusing and members will miss the replies and input on one of them.
The early XJ12 workshop manual lists the acceptable hot engine compression figures for 7.8:1 and 9.0:1 engines as 120psi to 140psi with a maximum allowable difference of 5 psi between cylinders. HE engines with their much higher compression ratios should produce considerably higher test numbers. Test gauges don't need to be that accurate because the most important issue for diagnosis is cylinder consistency. Similarly, starter motor condition and therefore cranking speed can affect the readings. Hence, my own gauge on a 9.0:1 pre HE engine gave readings of about 155psi the last time I checked my own car. Mike.
Okay, thanks Mike ... I have not been getting anything close to 155 psi and my pressure readings are pretty erratic. Just had to connect my Oil Cooler as I found that I was spraying oil out whilst I was at the other end turning the engine over.
Am planning to get a 'faster' starter motor as the engine does not seem to turn over very quickly - based on no experience but how fast modern engines 'seem' to turn over.
Nevertheless, seems with the erratic readings that I will have to strip the engine down ... didn't want to have to do that ...
Okay, took some Compression Readings today ... which were interesting. Ignoring the fact that variations between cylinders were enormous and demonstrate that I need to remove the heads, my readings (psi) were as follows:
A1 = 88; B1 = 125
A2 = 124; B2 = 152
A3 = 122; B3 = 178
A4 = 120; B4 = 130
A5 = 135; B5 = 115
A6 = 145; B6 = 125
I would like to think that B3 was not rogue as B2 was blowing slightly past the Inlet Valve ... potential to be higher than 155 psi when all valves lapped in?
That said, I am currently too busy to take on this 'rebuild' where this engine in now likely to sit in my garage for a few years whilst I do other stuff ... anybody looking for such an engine with only circa 5000 miles on it?
Regards, Wolfie and thanks for all information to date
A1 = 88; B1 = 125
A2 = 124; B2 = 152
A3 = 122; B3 = 178
A4 = 120; B4 = 130
A5 = 135; B5 = 115
A6 = 145; B6 = 125
Well, if the engine has to be stripped, you will get that chance to see which pistons are fitted! It does seem odd that one cylinder reading is so far above all the rest. Bearing in mind the engine has stood for a long time, barring B3, I'd have guessed it's a 9:1 unit with sticking piston rings. The mystery continues. Mike.
Hi and the joys of having a cheap Chinese endoscope attachment for my phone plus a bit of luck with angles down through the spark plug holes ...
Random look inside each cylinder and found a number stamped into the top edge of a piston, however ...
EA63056 or EAC3056
I am sure of the EA and the 056, but the 3rd digit could either be a 6 or a C - a little hard to make out ... quite sure that the next digit is 3 and very positive about the last 3 digits being 056.
Any clues to Piston Identification? 9:1 or 10:1? I typed EAC3056 into Google and it returned Dip Stick Tube ...
Regards, Wolfgang
EA63056 or EAC3056
Regards, Wolfgang
Wolfgang,
If you look on Jaguar's parts website (always look there for first to identify part numbers) you'll see that EAC3065 (the microfiche scan is a little indistinct) seems to be the part number on a High Compression Piston in a PA or PB cylinder & piston set for a pre-HE XJ-S engine.
Thanks Paul,
However, I really cannot find which website you are referring to? Also, all of the main Jaguar classic parts websites do not have this Part Number listed? Curious how you identify EAC3056 as being attributed to Pre-HE 10:1 Pistons?
Hope that you can clarify, TVM.
Kind Regards
Wolfgang
Kind Regards
Wolfgang
