Engine Surging
Posted: Fri Feb 19, 2021 2:39 pm
by Jag 1979
My 1979 fuel injected Daimler has an engine surge.
All seems fine when underload but, when coasting down hill the engine surges.
Also, sometimes when sitting in traffic the engine will start too surge.
If I turn the engine off then restart it all seems fine?
Re: Engine Surging
Posted: Sat Feb 20, 2021 12:41 pm
by mike020150
Is this a 6 or 12 cylinder car? Some models are fitted with over-run valves on the inlet manifolds and this is one possible cause. These valves are tensioned by springs which can weaken with time and can cause surging, more usually at idle. If guilty, the cure can be to adjust the tension of the springs by tightening the nuts on the centre spindles. Mike.
Re: Engine Surging
Posted: Sat Feb 20, 2021 12:57 pm
by Jag 1979
Hello mike, yes its a 6 pot.
I imagine that this spring is located on the throttle body somewhere?
Re: Engine Surging
Posted: Sat Feb 20, 2021 1:02 pm
by mike020150
If your car has one, the valve will probably be located between the inlet manifold and the air cleaner. Mike.
Re: Engine Surging
Posted: Mon Feb 22, 2021 12:09 pm
by Jag 1979
Mike< something interesting.
There is a small micro switch on the throttle body, and when I disconnect the wire it runs fine?
However, the revs go up to 2000rpm?
Wire put back on and the hunting starts again. If I turn the engine of and restart it the the hunting seems fine?
Regards Karl
Re: Engine Surging
Posted: Mon Feb 22, 2021 1:59 pm
by PaulGover
I wonder... there was a problem with the injected engine's air-flow meter which was cured by soldering a capacitor across a couple of terminals under the plastic cover. I vaguely think your symptoms might indicate either you need one now, or you have one that's either gotten disconnected or fried. Might be worth investigating.
