Fast Idle
Jag 1979
Fast Idle
Postby Jag 1979 » Sun Jan 17, 2021 7:32 pm
Hello all, I took my Daimler 4,2 series 3 1979 injection out for a drive today.
However, I noticed when stopped at the lights that the idle was high. It when down a little after after the second set of lights.
Once home, it was still very high?
Could it be the throttle body sticking open, or a water temp sensor?
Re: Fast Idle
Postby mike020150 » Mon Jan 18, 2021 11:05 am
It could be either of those suggestions but in cold weather, perhaps the engine hadn't warmed through sufficiently, especially if the thermostat is sticking open. Mike.
Andy P
Re: Fast Idle
Postby Andy P » Mon Jan 18, 2021 12:42 pm
Hello Jag 1979,
Here are a few threads about the high idle issue:
https://www.jaguarforums.com/forum/xj6- ... st-118719/
http://www.jag-lovers.org/xjlovers/xjfaq/idleadjust.htm
https://www.jaguarforums.com/forum/xj6- ... le-200247/
Hope you find them interesting,they might point you in the right direction anyway.
Good luck with resolving the issue.
Take care and stay safe.
Andy :D
Jag 1979
Re: Fast Idle
Postby Jag 1979 » Mon Jan 18, 2021 2:41 pm
Thank you Andy and Mike.
I will have a good read of the links sent.
Keep safe, kind regards Karl from Hastings
