I can`t tolerate dirty air or oil filters.
My favourite replacements are always from K&N sources for my 4.2 XJR. They feature ultra top quality filtration media with other internal parts being exceptionally robust and well constructed. These fabulous filters are the racing fraturnities favoured units.
The HP1014 spin on canister oil filter with a 1" removal hex lug and non drain back valve looks after the engine oil filtration.https://www.google.co.uk/url?sa=t&rct=j ... lCvCXPlDGH
My K&N air filter is a 33-2273 direct drop in panel filter. Its washable and re-oilable and is a once off buy. https://www.google.co.uk/url?sa=t&rct=j ... l_hpT4EE_m
K&N sell a "recharge" service kit which includes a water washable cleaning fluid and also the correct re-oiling fluid.https://www.google.co.uk/url?sa=t&rct=j ... 4qyUCqBCp1
A few pics now of my 33-2273 air filter having a clean and re-oil after 15k miles of road use. Yip, it was a bit mucky on the dirty side. To be expected. At least the muck was on the filter rather than having passed through the motor.
Here is the same filter having been cleaned using the highly effective spray on water soluble/washable deturgent.
Here it is again being reoiled.
And totally oiled, ready for further use.
I like these filters and have used them for years. Highly recommended.
I`m fanatical about clean air filters! K&N filter clean.
Re: I`m fanatical about clean air filters! K&N filter clean.
+1 for the K&N. In fact, Mike, it's reminded me that I've just done 6k on the one in my supercharged RR so it's time for a clean and re-oil.
Hi Mike - I don't know why your picture of a cleaned filter excited me but it did
I shall have to seek therapy - that can't be normal
Sadly David, there appear to be several of us with the new parts exitement desease. My own affliction is that I can recite any part number for any components that I`ve ever fitted, yet I still find that I can`t remember where I`ve left my reading specs!
This week I`ve fitted loads of new parts. One new heated windscreen, serviced the air filter, fitted a new header tank and had four new tyres. Thank goodness it was only a £75 policy excess for the new screen!
Yes - you're right. It is a disease. But it could be worse I suppose!
I'm a big fan of the K&N. It's a sensible long term investment as you'll never have to buy another air filter again. I enjoy the ritual of cleaning and re-oiling the used filter. There's a sense of renewal, even rebirth about it and I find it deeply satisfying. A bit wierd but there you are
You lot really should get out more.
Or less if you are having to replace bits all the time.
