Oil: 2.7 Tdvi Engine (specifically 2008 XJ with DPF)
Moderators:Popsjag, J44EAG
Partick-the-Cat
Postby Partick-the-Cat » Thu Aug 22, 2013 8:09 pm
The owner’s handbook specifies oils meeting the WSS M2C 913-B specification for both the petrol and diesel engines even ‘though the diesel has a DPF.
However the newer 3.0 diesel in the XF etc has M2C934-B specified as this is a ‘low-SAPS’ oil (an ACEA C1 oil) suited to engines with DPFs.
Interestingly Land Rover (I am told) now specify 913-B for all LR 2.2, 2.7 and 3.0 litre diesels WITHOUT DPFs, and 934-B for all the three diesels WITH DPFs; that includes the 2.7 !
However when I enquired of the Jag agent in Cheltenham and was told 913-B was the correct oil.
So ... what is special about the pre-'09 2.7 with DPF that it requires 913-B rather than 934-B ?
(Or, was the book printed before ACEA C1 oils were available [there were problems getting Castrol Edge C1 when the XF first came out in '09] ... and, unlike LR, have Jaguar just been slack in not updating their recommendations ?)
Is there some good reason why 934-B oils shouldn’t be used in pre-2009 2.7 engines, even when they have DPFs ?
(I was further confused when I discovered that several oil manufacturers now make an oil [notably Q8's Formula Exclusive C1 5W-30] that meets both the 913-B and 934-B specs).
2008 LWB (& sunroof) XJ Sovereign 2.7 Tdvi (Botanical Green)
robv12
Re: Oil: 2.7 Tdvi Engine (specifically 2008 XJ with DPF)
Postby robv12 » Fri Aug 23, 2013 8:47 am
I would suggest a call to our technical guys, David Marks or XJK Ltd for their views, numbers are in the magazine or on the website X-350 Forum pages under "Forum Contacts".
Partick-the-Cat
Postby Partick-the-Cat » Thu Mar 20, 2014 12:30 am
To answer my own question ... the 2012 Jaguar Vehicle Specifications Document (downloaded from JagDocs http://www.jagdocs.com) now specifies an engine oil meeting WSS-M2C-934-B (ie an ACEA C1 oil) for the 2.7 Diesel XJ (2003-10) with DPF.
This is a change from the 2009 Vehicle Specs Doc. which specifed WSS-M2C-913-B or C.
So, if you want your DPF to last then it's ...
Castrol EDGE Professional C1 5W-30
Shell Helix Diesel Ultra AF-L 5W-30
Mobil Super 3000 Formula C1 5W-30
Millers Oils XF Longlife C1 5W-30
etc etc
from now on.
marius.marusanici284
Postby marius.marusanici284 » Fri Oct 11, 2019 8:17 am
Hello,
Did anyone actually use WSS-M2C-934-B oils in a 2.7D engine?
I'm planning to change the oil in my 2.7D S-Type (with DPF), and I would like a confirmation that it's ok to do so.
In the past I was using Ford WSS M2C 913-B/Jaguar ST JLR.03.5003 oils, but there are better WSS-M2C-934-B/ST JLR.03.5005 alternatives :)
