Hi Guys,
Has anyone any info on replacing the rear electric sunblind on a 2003 XJ8
Re: rear electric sunblind
Hi, you might get a better response posting in the Interiors subdivision of the X308 section rather than the Archive subdivision of the Series XJ section. The Series XJs don't have blinds
1986 Series 3 XJ6 Sovereign
- 3.8etypephil
- Contact:
From the year quoted, the car should be an X350 (aluminium body), if so:Hi Guys,
https://www.zinref.ru/avtomobili/Jaguar ... h/1424.htm
https://www.zinref.ru/avtomobili/Jaguar ... h/1425.htm
Usually these just stick in the closed position through lack of use, so first of all get an assistant (a good looking female is best) to operate the control while you tug at the blind from the rear seat. If / when it frees, get your hand out of the way quickly!
Phil
2013 XFR
2008 XJR
2013 XFR
2008 XJR
