Couple of odd issues on the Super V8
Moderators:Popsjag, J44EAG
Davidqhog
Postby Davidqhog » Tue Jun 05, 2018 7:52 pm
At the risk of commandeering this forum, there are a couple of odd ones on the new(ish) car.
The windscreen washers don't work. The pump is okay, the switch in the car is okay (the wipers do their 3 swipes) but no water. The pump doesn't run when the wipers sweep. The pipes aren't blocked.
Any ideas, anyone?
Best regards,
David Q
Re: Couple of odd issues on the Super V8
Postby J44EAG » Wed Jun 06, 2018 12:46 pm
Some electronic interfacial issue perhaps. Corroded plugs and sockets or bad grounding are likely to be a prime cause for suspicion.
I`d initially be looking at the grounding points behind the front headlights. These are a notorious fail point. Go easy as you remove the nuts on the ali studs. Being ali, which could be well corroded, these studs snap off for a pastime. Have a new stainless steel bolt, washers and a nut to hand before you dismantle. At least you then have ready parts to repair if the stud snaps. See how you get on.
Davidqhog
Postby Davidqhog » Wed Jun 06, 2018 4:10 pm
Thanks Mike! I'll check them out. Are they behind the OS or NS headlamps?
David Q
Postby J44EAG » Wed Jun 06, 2018 10:49 pm
Both sides behind headlights. Also one somewhere in the region of the pollen filter box, near side rear of engine bay.
PaulGover
Postby PaulGover » Fri Jun 08, 2018 4:27 pm
I had a similar problem caused by sludge in the washer bottle. You say the pump is OK but doesn't run, so it's probably not this, but if it could be, here's a writeup I did some time ago.
1986 XJ6 Sovereign Series III
1991 XJS V12 "facelift"
2021 I-Pace SE
Davidqhog
Postby Davidqhog » Sun Jun 10, 2018 11:47 am
Thanks Paul, I'll get a roundtoit at some point!
