Leaking boot/ body work
Posted: Wed Feb 05, 2014 12:28 pm
by barrywi
If anyone has a leaking boot or water ingress please email me for a copy of a Jaguar PDF covering the problem. I have been unable to upload it to here.
Re: Leaking boot/ body work
Posted: Wed Jul 22, 2015 9:46 am
by AlistairCampbell
I have 2006 XJ and rear footwell is filling with rain water which appears to be in either through door sea
S or rear window and running down between rear seat back and door frame. Any advice welcome. Thanks Alistair campbell
Posted: Wed Jul 22, 2015 10:58 am
Most cars have a plastic membrane stuck with flexible sealer to the inner door frame panel with cut outs for door linkages, cables etc.
It might be that if the door card has been previously removed and some works carried out inside the door, the membrane may have been torn or not replaced correctly. In such an instance rain water will almost certainly run down the inside of the door and flood a foot well. I`d remove the door card and see if such a defect exists. Either fit a new membrane from Jaguar or make one up from a piece of stout builders DPC material. Obviously ensure sealer is present all round the membrane to attempt to fix such a problem. Take a look and see what you can find.
Posted: Thu Jul 23, 2015 9:11 am
by AlistairCampbell
Can you email PDF file re leaking boot/bodywork to me ? Thanks Alistair Campbell.
alistaircampbell51@gmail.com
