Hello all
My recently acquired xj8 sport arrived with what looks like 2 passenger side mirror glass fitted. I have sourced the correct wide angle driver's glass but would appreciate help in how I go about fitting it
Thank you
Martin Smith
Replacing driver's mirror glass
Re: Replacing driver's mirror glass
Hi Martin,
Should be a video on you tube of it, but essentially as follows: Position mirror so outside edge is extended, that is mirror turned towards the car. Pull the outside edge towards you and at same time pull it away from mirror body, that should release the outer edge of the clip and it will then lift off. Remove the terminals for the heater element and photochromatic dimming if present. Note which terminals they slot onto. Refitting is the reverse, ie put inside edge on first, pull towards you and push back onto the clip, should feel it click as it engages.
XF Sportbrake 2020 / XK8 1998
Martin,
Whilst you're playing with the mirror, maybe have a look at the inevitable awful corrosion buildup that happen in x350 mirrors. See my thread here:
viewtopic.php?f=280&t=8341
