X350 Lambda sensors. Parts number listings.
Posted: Fri Jan 13, 2017 6:51 pm
Here is a list of part numbers for Lambda sensors.... There are many, so choose carefully and have your Vin to hand when searching. Make sure you chose the correct engine size and model variant! You can check for best prices after obtaining the correct part numbers for you particular car by then typing the number into your search engine browser bar. You might be quite surprised at the prices you can obtain by doing a bit of browser searching. Where possible, always try to obtain genuine Jaguar parts. This is particularly important with sensors and other electronic parts where they are tolerance critical. Some after-market parts can be manufactured with tolerances way out of limits for our cars. If in doubt, ask a supplier to confirm what he will be supplying you with. If in doubt, don`t buy!!
https://www.google.co.uk/url?sa=t&rct=j ... Al_4mhuHyQ
