Rear Suspension Low Warning - Handbrake Malfunction
Posted: Fri Sep 16, 2011 11:50 am
Hello Guys (and Gals?),
I had an interesting warning come up on the XJ4.2 Sport, with 4 passengers in the car: "Warning - Rear Suspension Low" (or words to that effect). Warned passengers of weight issue (Ho, Ho!) and got them out. No effect - warning still there. Then worked out that the warning came on when I was reversing out of our drive (with passengers), so could be electrical handbrake stuck on, causing rear radius arms to "tuck up" and create warning.
Got underneath rear axle (car on axle stands, folks) and checked electrical actuator on handbrake: Sure enough, mechanical linkage was seized (despite car having history of Jaguar main dealer servicing until my ownership - you see why I do my own?!). With a bit of "Cold Setting", as we engineers call it (or judicious bashing with a Birmingham screwdriver, for everyone else) and a good squirt of penetrating fluid (careful of brake discs) into the whole mechanism and linkage, I got the rear handbrake working properly. Then lubricated all joints / sliding parts properly.
Always check that the brakes are adjusted, after this job. Brake on: wheels locked; brakes off wheels free. Easy Fix.
Good luck.
Good luck.
