Ride Heights
What should the correct ride height be on the X-350 ?
- 3.8etypephil
- Contact:
Re: Ride Heights
The following should give you all the information that you could possibly need:
https://www.jaguarforums.com/forum/xj-x ... ht-178076/
https://www.jaguarforums.com/forum/xj-x ... ost1597274
Phil
2013 XFR
2008 XJR
2013 XFR
2008 XJR
Re: Ride Heights
Front 386 ± 15 mm
Rear 373 ± 15 mm
Ride height is measured from the centre of the wheel to the apex of the wheel arch, through the wheel centre line.
This is from the workshop manual.
Rear 373 ± 15 mm
Roger S
Aberdeenshire
Early E
X350 - 2005 Super V8
1962 MGB
Aberdeenshire
Early E
1962 MGB
