Air Suspension Height Calibration
Moderators:Popsjag, J44EAG
SwedishViking
Postby SwedishViking » Tue Apr 30, 2019 8:32 am
Hello,
I get an error after programming the ride height using SDD with 156 SW version and Mongoose Pro after
  • clearing the faults (new sensors and one damper) with no codes logged (green ticked)
  • the Car having the correct ride height within +5 millimeters; and
  • being on a flat surface.
The Car was taken for a test drive and behaved as it should.
Has anyone got any ideas on why this may be the case, could it be the compressor not performing as it should in a 2003 model with 150K mileage?
Best regards Robert
Re: Air Suspension Height Calibration
Postby mike020150 » Fri May 03, 2019 11:50 am
If the compressor has covered 150,000 miles, it has done remarkably well and therefore has to be a prime suspect. Mike.
