X350 Air suspension - plastic pipe connector - SOLVED
Moderators:Popsjag, J44EAG
bouncer99
Postby bouncer99 » Thu Jan 24, 2019 10:35 pm
I have discovered that the right angled plastic pipe connector which connects into the body of my air suspension compressor is broken. Is this part available separately. I really don't want to have to buy a whole new compressor.
Re: X350 Air suspension - plastic pipe connector
Postby J44EAG » Fri Jan 25, 2019 9:58 am
If not available from a Jaguar Main Dealer parts department, then I would suggest you contact Eurojag for a good, used second-hand component. Their details are in the magazine or they can be found online. Their prices are fair, their parts are only the best and they are a pleasure to deal with.
Hope that helps.
Postby ptjs1 » Sat Jan 26, 2019 8:02 pm
bouncer99,
If you look at the parts website online, it seems to indicate that the pipe isn't sold separately. However, you'll see that you can buy the 4mm and 6mm pipes, so perhaps you can effect a repair with these?
bouncer99
Re: X350 Air suspension - plastic pipe connector - Solved
Postby bouncer99 » Sun Feb 10, 2019 12:54 pm
Thanks for all input.
I managed to get exactly the correct part from Miessler Automotive for 25 Euros. They have a wide selection of suspension parts and well worth checking out.
