A quick background, the heating on the drivers side (right hand) is be poor to non-existent.
Flushed the heater matrix little or no improvement.
Then found in the manual there should be water movement in the header tanks with the ignition on an engine not running. Remove fuses in turn to the auxiliary heating pump supercharger intercooler pump. Remove the air bleed plug on the top of the intercooler with the auxiliary heater pump fuse removed, I got someone to turn on the ignition and had water movement replaced bleed plug, so supercharger pump working.
After fruitless attempts at trying to discern whether the auxiliary heater pump was running by touching and listening with a stethoscope I still couldn't decide whether it was running or not.
So decided to remove it. (I decided to remove the front panel of the under tray so as to drain the coolant rather than have it go everywhere undoing in the hoses) gaining access to the pump is not that difficult removal of the header tank and the top radiator hose, the worst part releasing the hoses from their spigots.
On the bench the pump did not run so I decided to strip it, If there's interest I will described that with photos later (If I can find out how to post them). The fault the brushes worn out, made up new brushes and got the pump running, which is exceedingly quiet and smooth running no wonder is difficult to ascertain if it is when in the motor.
As there are alternatives/upgrades for the supercharger pump I thought I'd take the opportunity of trying to ascertain the performance of the auxiliary heater pump, results you can read below.
From my investigations there seems to be no substantial difference between any of the Bosch PAA series pumps. I can only assume the difference is in the impeller and scroll design to alter their outputs and may be the electric connection socket. How this account for a price variation from £32 to over £300 I really don't know? Further the assembly/part number only differs in the last three digits and as you can read below, these digits have little bearing as to the pumps output with the 039 pump having a lower output than the 034 etc.
Below is a link to the Bosch catalogue it is in PDF the pumps on page 118
https://www.silicon-ark.co.uk/datasheet ... otoren.pdf
I cannot find any information on the pump fitted to our car 086 or any alternative offered the only two suppliers making offerings of £163 and £146 respectively, not the end of the world I grant you but I do find it irksome when you see other models of these pumps being sold for £100 and more less.
I did read on another forum that Bosch only make four versions of this pump plus a 24 V version, which may be why I can only find information on five PAA pumps?
So could ours be the model 034 whose output would seem to be close to my first method of testing or the model 024 which again is close to my second method of testing.
As I said earlier your comments would be welcome, in the meantime I'll put my original repaired pump back in to check if the heater is working, if not it may mean heater matrix replacement (please no
Regards Bill Dagworthy.
Auxiliary heating pump on Jaguar X JR 350 2004.
Pump.
Bosch assembly number 0 392 020 086.
2R8H-18D473-bc.
On motor body.
PAA Y 12 V D 392 020 071.
Ford. 1W4H-18D-474- AA.
I can only find five PAA Bosch pumps with any spec associated with them they are all rated at 0.1 bar delivery pressure and one of these is 24 V.
Hence my figures against a 1 m head (0.098 bar).
Outlined below are the two methods I used testing the auxiliary heating pump from my car,I feel method 2 the more representative. As I have not be able been able to find any figures on the pump fitted to our cars (086) I feel this is the closest Iam likely to get without knowing resistance through the heater matrix (new) and the associated pipe work, leaving aside a proper test rig.
First method testing output.Discharge measured into a bucket
Pump inlet connected into bottom of a bucket water head 50 mm above inlet.
Pump discharge via 20 mm ID pipe standing upright 90° bend at outlet.
First attempt at 1 m head pump would not discharge/lift. Reduced head in three steps of 50 mm until pump discharge at 850 mm head.
Giving approximately 0.083 bar head pressure.
Average of two runs discharging into a bucket.
11 L in 45 seconds = 14 L a minute.
Second method testing output discharge measured into a bucket.
Pump inlet connected into bottom bracket.
Outlet vertical pipe pulled 90° bend at outlet height 13.5 mm ID the same ID as pump outlet.
Set at 1 m head (0.098 bar)
Average of two runs.
10.8 L in 1 minute 32 seconds = 7.2 L a minute. Maybe of interest. Pump connected as in method two.
Outlet via 18 mm ID rubber hose and approximately 200 mm head 0.02 bar.
Discharge 12 L in 35 seconds approximately 20 L a minute.
The four Bosch PAA pumps I found information on being the same model as our 086 pumps as follows.
Part number 0392 020 039 delivery 530 dm3 hr (8.8 L a minute) delivery pressure 0.1 bar.
Part number 0392 020 034 delivery 750dm3 hr (12.5 L a minute) delivery pressure 0.1 bar.
Part number 0392 020 024 delivery 500dm3 hr (8.3 L a minute) delivery pressure 0.1 bar.
Part number 0392 020 064 delivery 1200 dm3 hr (20 L per minute) delivery pressure 0.1 bar.
The two pumps used for replacing upgrading supercharger intercoolers figures are as follows.
Part number 0392 022 002 delivery 1200 dm3 hr (20 L a minute) delivery pressure 0.3 bar.
Part number 0392 022 010 delivery 1400 dm3 hr (23 L a minute) delivery pressure 0.3 bar
