Alloy wheel referbishment economy style.
Posted: Tue Nov 17, 2015 3:43 pm
I don`t have money to waste or can I often afford to pay people to do jobs i can do myself.
Refurbishing alloy wheels is not as daunting as you may think or does it need to be expensive.
My new to me X350R has a few issues to get it reasonably sorted. For an eleven year old car most parts have survived reasonably well. Not so perhaps the insides of the wheel rims which were excessively corroded and had me more than a little concerned. Whipping the worst and the most corroded wheel off the car this morning for further evaluation, i decided to pull my finger out and correct the issue before further corrosion continued its manic actions. In short, the inside rim of the wheel was a corroded mess with paint bubbling off and bare aluminum deep pit corrosion being noted.
After a complete soap scrub of the rim with a Scotchbrite pad, things looked a little better. A rinse off and time to get started with an angle grinder fitted with a medium abrasive flappy garnet disc. Ten minutes work and things looked more promising and under control. A change to a fine flat pad disc leveled out paint edges and removed most of the grey corroded aluminum surface areas where the finish had broken down. Washed off again, inspected and with final details attended to, I brushed on a 25% strength solution of dilute hydrochloric acid and left the acid to brighten and pacify any remaining deep pitted areas.
The solution brightened up the nasty areas to fresh metal and the whole rim was again pressure washed, dried, masked up and rattle can primed with aladine based etch primer. This is standard aircraft construction and repair regime material.
The rim then stood in front of an infra red lamp for half and hour, three silver finish coats of rattle can spray paint were applied and once again cooked off in front of the lamp.
Costs for the job.
A quarter of a can of etch primer, say, £2.
One can of silver spray paint from the £1 shop.
Masking tape, 30p.
A table spoon of neat 36% hydrochloric acid, say, 20p.
A bit of electricity for the grinder and the lamp, say,50p.
Total cost for one rim repair is about £4 and a couple or three hours of my time.
The finished result is currently hardening up under the infra red lamp and will be replaced on the car later this afternoon.
I`ll now work my way around the other three wheel rims and refurbish as time and conditions allow. Had conditions outside allowed, I would have done all four wheels in one hit. How I hate these winter conditions. Not nice a all with storm Abigale just starting to hit us. One wheel done and three more to go. Progress takes time.
HSE tip and warning here. Wear rubber gloves, goggles and other suitable personal protection whilst working with strong acids. Have a bucket of water handy in case of an incident. 36% hydro acid is evil stuff and fumes alarmingly when you open the container. Use in a ventilated area and ONLY ADD ACID TO WATER, NOT THE OTHER WAY AROUND. IF NOT HANDLED CORRECTLY IT WILL JUMP BACK AT YOU AND MAY CAUSE PERSONAL DAMAGE. STICK TO THIS GOLDEN RULE! Acid takes no prisoners!
