Gearbox Fault
Posted: Sun Feb 21, 2021 9:41 am
by Tcollis
Good morning.
My car has developed a gearbox fault the wording of which is displayed on the dashboard. It’s accompanied by the rpm going up and down and sounds like it is trying to select different gears. For a while yesterday it felt like it was stuck in third.
The rpm thing also happened about 18months ago and I had a transmission service and new oil which cured it.
Is it possible the gearbox is leaking fluid?
I will book it in with the garage tomorrow but would appreciate your views on what it might be?
Thanks very much,
Tim.
Re: Gearbox Fault
Posted: Sun Feb 21, 2021 1:00 pm
by PaulGover
One common fault is a failed rear right speed sensor. The gearbox software checks the engine revs against the rear wheel speed to check the right gear is engaged. If it gets no signal, it decides your box is now a worthless load of scrap; instead of phoning the AA, it puts you into "limp home" mode of fixed 3rd gear.
You or your garage can diagnose the problem with a OBD-II scanner which will, among several other frightening warning codes, say the speed sensor is broke. The fix is a new sensor - dead easy to fit. Jaguar ones are expensive; the usual sources can provide good equivalents at a much better price. You do need to ensure it's a proper replacement for you car; it's not a generic one-fits-all unit.
Re: Gearbox Fault
Posted: Mon Feb 22, 2021 1:53 pm
by Tcollis
Thanks Paul, much appreciated.
Hopefully it will be that and nothing more serious.
kind regards,
Tim.
Re: Gearbox Fault
Posted: Fri Feb 26, 2021 8:24 pm
by Tcollis
Hi Paul, car is booked in but not until 12th March. Do you or anyone else think it’s ok drive before then on local journeys? I don’t like to leave it standing too long.
Thanks very much,
Tim.
Re: Gearbox Fault
Posted: Sat Feb 27, 2021 4:52 pm
by PaulGover
I managed to get mine to run normally for a bit by (a) letting it idle for a couple of minutes before moving off, and (b) sticking to low speeds and small throttle openings and smooth acceleration, a bit like running in. I think it let the electronics adapt to the weaker signal from the speed sensor, rather than present it with an out-of-the-normal response directly after starting. Assuming that's your problem.
Re: Gearbox Fault
Posted: Sun Feb 28, 2021 8:17 am
by Tcollis
Thanks Paul, that’s precisely what I have been doing. In fact yesterday when driving the fault did not manifest itself at all, so it sounds like my fault is as per your diagnosis. I hope so as it looks like a simple enough fix.
I’ll be folks know how I get on.
Tim.
Gear Lever Locking
Posted: Wed Mar 10, 2021 2:52 pm
by jarturner442
I have a 2008 X358 with just 21000 miles done - I have only owned it a few months
I have kept it in the garage over winter - just taken it off SORN from 1 March.
It is running beautifully but I have noticed that on initial start up from cold the gear lever will not move out of PARK.
I sit there for a moment and after two or three attempts it will move as it should - and the problem does not occur again until perhaps the next time I start it from cold. Then after a minute or so all is well.
This does not worry me too much except that it might be the early stages of a problem looming ?
Any comments/advice would be appreciated
Thank you
Richard
Re: Gearbox Fault
Posted: Thu Mar 11, 2021 10:18 am
by Andy P
Hi Richard,
You might find this thread will help you.
viewtopic.php?f=284&t=14611
Enjoy your car .
Take care.
Re: Gearbox Fault
Posted: Fri Mar 12, 2021 6:31 pm
by jeff1954
Speed sensor? Do you mean ABS sensor if so if your handy enough why don't you take the wheel off and have a look yourself, it might just need a clean up.
Jeff
