If ever there was justification for changing the oil at each and every 60k interval, that bucket of black oil is it!
That is what you get when oil changes are neglected. The black content is burned, carbonated, contaminated and completely worn out oil. Its lubrication properties will be non-existent. Without putting too fine a point on it, running with oil in that condition will have caused a high degree of wear to gearbox components with consequential reduction in gearbox life.
With a re-built gearbox easily able to consume at least £3k in hard cash, it makes sense to spend around £350 at each 60k (if not earlier) mileage occurrence. It is a total "no brainer" really. Anyone buying one of these now getting elderly cars really should get the gearbox oil change done as a matter of urgent priority. Either that or have a £3k wad of cash waiting in the glove box for a new gearbox.
In my experience, the diff oil should also be changed every 60k, not 90k as the schedule suggests. It needs removal from the top of the diff case when hot via a vacuum extraction unit. Refill is quick and easy. What gets extracted at 90k is almost certainly likely to be as seen in the shot of the oil in the previous post on this thread.
Glad you got that oil changed. It was long past its sell by date.
Gearbox service
Re: Gearbox service
I've just booked my XF in for a Gearbox Oil and Filter change at Lookers, Amersham, it's due it's annual service under the plus 3 scheme I'm a member of (89000mls), so don't pay for the service there and then but spread the cost over a year. I have been quoted £600 to £700. for the gearbox oil change alone at the same time, this isn't covered under the scheme. Initially stupefied but calmed down after reading this string and going back over my S-Type invoices when the Torque Convertor failed eventually resulting in a new gearbox in 2012 (at 86000mls). One of the things they tried was changing the oil. I had to pay for that at the time. But when that didn't work and JLR got involved the final cost to me was the value of the new gearbox and ancillary bits only (£2592). At the time the oil change was just short of £400 for the oil and filter , I didn't have to pay for the oil and filter in the new box. When booking my car in it's worth noting that the Service person I spoke to said it doesn't need doing it's sealed for life. Having experienced one gearbox failure , and I tow a caravan, I am not about to push my luck. I am also asking for a sample of the oil removed, I'd like to get it analysed any ideas.
Dave
Dave
Dave Hart
Re: Gearbox service
Dave,
As you will appreciate this is the x350 forum and different aspects and views will pertain to your XF. It may be worth posting in the XF forum to get owners opinions.
However, a couple of tboughts:
The "sealed for life" concept is garbage and any decent jaguar service department knows that. Even ZF who make the x350 box will say that "life" = 60k miles. Ask your jaguar service rep if that means you have a lifetime warranty on the box! I think not!!
There are a number of companies who will undertake oil analysis on used oil. Google is your friend here.
Re: Gearbox service
The phraseology said filled for life all those years back. How long is life? That was the question.
Many owners paid the price for this crazy linguistic bull~~~~! PR sales pitch drove everyone into a false sense of security. Engineering sensibility got brushed aside by so called knowledgeable people who just didn`t know what they didn`t know. As often said, these people had enough knowledge to be dangerous. If they had an gumption at all, they might have enrolled on an accredited transmission training course and learnt what does happen when oil degrades rather than what their piers might have told them in the pub.
If one of those individuals could give me ten reasons why gearbox oil should not be changed, I`d be happy to give them a thousand reasons why it should.
Owners pay the price for bad advice when scrubbed up clean and tidy service desk staff swing the lead. The grease monkey covered in muck gets ignored and his engineering qualifications and experience get belittled by the shiny suits.
I`d not be giving my work to a business that doesn`t want to do it. Would you trust them to change the oil out of your sight line? They could bring you back any oil sample. How would you know it came from your car or just out of the workshop compressor! I`d find a local independent such as Tom Lenthall at Finchampstead who understands the importance of oil changing. At least at Toms, you can watch the work being done.
Until dealer staff acquire the correct knowledge and treat well informed customers with respect for that knowledge, I`d give them a very wide berth even at the expense of having to travel a few more miles to get a proper job done.
Re: Gearbox service
Hello Folks
Thanks for the prompt response, your comments echo my thoughts precisely. I've decided to cancel the oil change with the main dealer and go to an Independent . I'll stick with the service as I've paid for it, at least I get a vehicle report although given the report last year that was questionable so it needs to be taken with a bucket of salt, they couldn't even get the mileage and date of registration right.
Dave
Dave
Dave Hart
Re: Gearbox service
Ok approaching this from a different direction,is there a time span that the gearbox oil should be changed within,the reason I ask that is that my X350 while being nearly 14 years old still hasn't got anywhere near 60K miles,presumably the oil will degrade with time even if it isn't doing the miles.
I must admit to having been amused when I was first shopping for an X350 & read about the need for the gearbox oil & filter changes almost straight after reading about them being sealed for life,really crazy isn't it!
Re: Gearbox service
The wording said "filled" for life rather than sealed...subtle difference.
Jaguar never actually made the gearboxes themselves.The revised attitude as regards the need for gearbox oil servicing came from the makers of the unit themselves, ZF Transmissions. Failures did ZF reputation no good at all. So from initially spouting "filled for life", ZF then advised an oil and sump filter change be added to Jaguar (and also other makes of vehicle using the same gearbox) service schedules in an attempt to reduce transmission failures. That edict eventually became accepted at Jaguar Main Dealerships. However, some service desk "clerks" still remain uninformed or forgetful that gearbox oil and filter changes form part of a scheduled service scheduled to be actioned at each and every 60K service. The same goes for supercharger oil changes at the same intervals. So if any service desk wallah tries to tell you otherwise, he is not doing his job correctly.
As regards hard time rather than mileage, a glance at a typical Jaguar service inspection/action sheet will tell you at what mileage or time limit any action should be applied. Not having a sheet to hand right now, I would expect that the recommended gearbox action be "every three years or 60k miles, or which ever comes first". That may be a cautious time figure but would certainly help remove acidic or condensation loaded oil before it had the chance to cause corrosion to form inside the gearbox. In my opinion changing oil every 60K is excellent advice but personally would change the oil on hard time about every five years. I see that as a reasonable time period which shouldn`t generate issues.
I`ll add that when I had to have one of the early S-type Ford derived Bordeux gearboxes rebuilt, Bristol Transmissions recommended an oil change every four to five years regardless of mileage covered.
- RichardSEL
Re: Gearbox service
Last service sheet I saw was JTP 918 English published by Jaguar Cars Limited, Service Communications for the XJ8 series. That didn't have an ATF section. I've added it to my .doc version. If anyone wants a copy PM me an email address<snip>
As regards hard time rather than mileage, a glance at a typical Jaguar service inspection/action sheet will tell you at what mileage or time limit any action should be applied. Not having a sheet to hand right now, I would expect that the recommended gearbox action be "every three years or 60k miles, or which ever comes first". That may be a cautious time figure but would certainly help remove acidic or condensation loaded oil before it had the chance to cause corrosion to form inside the gearbox. In my opinion changing oil every 60K is excellent advice but personally would change the oil on hard time about every five years. I see that as a reasonable time period which shouldn`t generate issues.<snip> Mike
I can't attach it here (Astromorg has a .pdf version =ditto=) coz it's not a .jpg
Re: Gearbox service
Thanks for the replies guys,the car had had the same owner for 10 years when I purchased just over a year ago,it came with all the service records from Guy Salmon Jaguar in Coventry,one thing that notably seems to be missing is any mention of changing the gearbox oil & filter so I just know it is something I need to get done asap,just out of curiosity I checked the cabin pollen filter soon after I bought the car & that obviously hasn't seen the light of day since it left the factory so I do wonder what Jaguar dealers do in a service to justify the cost
