Fitting dashc am
Moderators:Popsjag, J44EAG
sportbrake
Fitting dashc am
Postby sportbrake » Tue May 09, 2023 9:33 am
Could someone please recommend which fuse to use to hard wire dashcam in 2006 X356 XJ8?. Hopefully I can use the fusebox on left side of dashboard. Is there an obvious earth point? Many thanks. Chris
PaulGover
Re: Fitting dashc am
Postby PaulGover » Tue May 09, 2023 10:03 am
My choice was to use a cigar lighter/accessory plug into the socket behind the glove box. But if you've already used that, or you've bought a dashcam with a fuse socket blade and no accessory plug, you'd obviously want a suitable fuse. Sorry, I can't help with that.
sportbrake
Postby sportbrake » Tue May 09, 2023 3:24 pm
Thank you for your helpful. Chris
sportbrake
Postby sportbrake » Tue May 09, 2023 3:26 pm
Thank you for your helpful reply. Chris
sportbrake
Re: Fitting dashcam
Postby sportbrake » Sun Jun 04, 2023 1:12 pm
I am unable to find the internal fusebox in my 2006 Jaguar XJ8 X356 (Japanese import) in order to fit dashcam. Can anybody help please? Chris
andypryce
Postby andypryce » Sun Jun 04, 2023 8:51 pm
From memory passenger footwell area..
XF Sportbrake 2020 / XK8 1998
sportbrake
Postby sportbrake » Fri Jun 09, 2023 5:06 pm
Thank you all. The fusebox is located in the drivers footwell on right hand side and awkward to get at. But all done thanks. Chris
