Can anyone advise as to the position of the ECU on an 2007 XJ 358.
I have XJ 350 and no the ECU is under the pollen filter box.
A friend who owns the XJ 358 says he has looked but it isn't there?
So confirmation as to its position would be much appreciated.
Regards Bill.
ECU where is it on an XJ 358
- 3.8etypephil
- Contact:
Re: ECU where is it on an XJ 358
It is under the pollen filter, access is from inside the passenger compartment, behind the glovebox.
Phil
2013 XFR
2008 XJR
2013 XFR
2008 XJR
Thanks very much for the prompt reply.
I'll pass on to my friend and tell him to have a closer look.
I've never really had to go there on my 350 but I had to move the pollen filter box for some reason some time back and I remember I could clearly see the ECU. Is it the same on the 358 or do you have to access it by removing the passenger glovebox.
Regards Bill.
Regards Bill.
- 3.8etypephil
- Contact:
As far as I know they are the same from 2006 onwards, but I would go in via the glovebox regardless, especially in today's weather.
Phil
2013 XFR
2008 XJR
2013 XFR
2008 XJR
