Bluetooth Module.
Moderators:Popsjag, J44EAG
mstanley3814
Bluetooth Module.
Postby mstanley3814 » Wed Feb 20, 2019 7:17 pm
Think I know the answer but want to check....
The Bluetooth module has failed on my 2007 XJ (X350) as the phone is no longer working properly.
The questions I have are;
1. Where is it.... I think it is the area of the CD changer in the boot but I'm not sure?
2. Is it worth fitting a module from a later model maybe... If so does anyone have a part number that works properly??
Any help is always appreciated!!
Thanks.............
SwedishViking
Re: Bluetooth Module.
Postby SwedishViking » Fri Apr 12, 2019 7:07 pm
The Bluetooth Module is fitted at the bottom of the DVD / CD / Sat Nav stack in the boot. Unless you have module 7W93-10D893-AA for 2008 to 2010, I suggest you upgrade to it as it allows later phone models and 5 units pairing. For pairing use code 1313. Scroll down for better info here: viewtopic.php?t=9892
Best regards Robert
