Front fog light bulbs and front headlight upgrade
Moderators:Popsjag, J44EAG
Tcollis
Postby Tcollis » Sat Feb 27, 2021 9:42 am
Good morning,
Could anyone recommend a good supplier of bulbs for my front fog lamps as they have both blown.
Also I would like to replace my front headlight bulbs as they are yellowish and not great in winter. I would appreciate people’s views on options, costs and results.
Thanks very much,
Tim.
PaulGover
Re: Front fog light bulbs and front headlight upgrade
Postby PaulGover » Sat Feb 27, 2021 4:49 pm
I assume your car hasn't got High Intensity Discharge lights. I'd buy some named brand ones at Halfords or equivalent. You are only supposed to fit the same spec. bulbs as already fitted, so in theory brighter bulbs can be failed at MOT or cause the fuzz to stop you - though that's much more likely to be the result of misaligned lamps than the bulbs!
Edd China ventured the opinion on Wheeler Dealers that cheap bulbs were simple glass rather than quartz, and hence much shorter life and brightness, so I'd steer clear of anything from eBay or elsewhere that looks particularly cheap.
1986 XJ6 Sovereign Series III
1991 XJS V12 "facelift"
2021 I-Pace SE
