Hi All
I took my car today ( Sovereign 2.7 Diesel) to my mechanic today to try and find a water leak. He was under a bit of time pressure and so had a quick look and was able to see water dripping down near the passenger side turbo. He didn't want to go ripping things apart to try and find the leak without know what he was getting into and would prefer to find it without stripping down the engine to the point that that car if off the road for a few days....So he asked did I have images or drawings of the passenger side of engine ( my car is RHD) . I have looked online but can't find anything other images of used engines that are for sale, and that might do him... but does anyone have assess to better drawing or images.
Also for my own perspective does anyone know of common causes of water leaks around this area
Charlie
Coolant Leak by Turbo
Re: Coolant Leak by Turbo
Charlie Have a look on the S Type forum under cooling system there's some links there of hose diagrams. Your leak may be coming from the EGR valve which are water cooled. I'll try to find another link from another forum which is a bit more explicit and get back to you.
Jeff
Jeff
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
https://drive.google.com/file/d/1CUqXwq ... sp=sharing Hi Charlie try this link it's for the S Type but the Diesel engine is the same as yours. The pages you need start at 1371 Hope this link works as I'm not very good at this sort of stuff. You might have to open this via google.
Jeff
Jeff
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
