Overheating XJR
Posted: Wed Aug 09, 2017 7:45 am
Hi All,
Any light you can throw on the below or any advice you can offer would be greatly appreciated.
My 2006 XJR is driven from London to Ayrshire, West Coast of Scotland without any problems. Car is MoT'd, a clean bill of health in that respect.
10 minutes after leaving the MoT station to take the car for a service the temperature gauge shoots up into the red. I pull over and switch off the engine. Checking under the bonnet all seems to be ok, no hissing or clouds of steam. I get back in the car after 5 mins and the temp gauge is back to normal so I try to continue. 5 mins later the same issue. As it's raining like hell I call the RAC and have the car trailered to my local Jag specialist around midday. I call them at 4:30 pm and they say they have been running the car all afternoon and can't get it to overheat!! Service is done the next morning and the car tested again by them, again no overheating, so I pick up the car late afternoon.
I have the car 10 mins and the previous morning's issue returns, I'm getting a bit paranoid now, so straight back to the specialist. This time coolant appears to be being forced out of the expansion tank pressure cap over the top of the engine. A replacement pressure cap is fitted, the coolant topped up, engine run for a while and all seems ok. It runs ok for the rest of the day. The following day I drive on the motorway for around 5 hrs then the problem returns, fortunately close to a service station, so I pull in and inspect the car. Same problem with the coolant appearing to be forced out of the pressure cap. So I gently release the cap, top up the fluid and wait for 20 mins. Temp gauge is now normal so I gingerly set off, being prepared at any moment to have to call the RAC once again. I drive 3 hrs with no problem then 200m from the end of the journey it happens again.
Apologies for the ramble but I wanted to try to convey all the events. Any ideas??
Many thanks,
Dave
Many thanks,
Dave
