Thermostat housing
dougmead2004338
Does anyone know or have a thermostat housing for a 2003 XJ8 X350 part number AJ89485
dougmead2004338
Re: Thermostat housing & the lack of!
Just a heads up guys! Could not find a thermostat housing for the 2003 X350 so had to purchase abroad (USA):
£245.10p for the housing (Original Jaguar price £156 ish)
£160.27 for postage
£45.58 for the Import Tax
Total : £452.95p
Apparently they do not make them anymore
SNG Barrett have them on back order some customers have been waiting many months.
Brit parts do not have any either.
Could not find any aftermarket parts either, they make ally aftermarket for the years above and below I think but not for this year 2003 - 2009!
Needs must when the devil drives!
There goes the money for the new headlining!!!!!!!!!!!!
This is my daily rider and have had her off the road for 4 weeks now!!
£160.27 for postage
Total : £452.95p
Too late for the OP by British Parts list https://www.britishparts.co.uk/jaguar-p ... t-aj813558 £32 plus VAT for replacement alloy thermostat housing
Er, that's not the same part; it says it's for a V6 and I suspect the OP has a V8 model. (It would have helped if the OP had given a more exact model description and VIN). Looking at SNG Barratt web site the thermostat housing for later versions of the V8 are stock items, so it seems that buying an early model example can be problematic with spares. The picture of the wanted part number looks quite different to later versions, but it could be that a later part would fit with some adaptation of hoses etc.
1969 Triumph Daytona rider
Previous XJs:
X300 3.2 in Spruce / Barley
Previous XJs:
dougmead2004338
Update: Part fitted but it seems my expansion tank is leaking also.........I had this replaced 27.06.2023 by a Jaguar specialist? Cost me £61.01p which sounds cheap as the OE part cost £85 ish! Garage tells me it is aftermarket......I am disappointed as is the filler cap. Also the thermostat which they replaced does not actually fit tight!. Booked in for Monday to have new OE expansion tank .
....presumably by a different "specialist" this time?!
